time2roll
Feb 03, 2017Nomad
otrfun wrote:battery will be a little less than 50%. It is constant amps not constant power. Actual power extracted diminishes as voltage tapers off. More power is extracted during the first 70 minutes vs the second 70 minutes.
If it is 0 percent, is it generally correct to assume that 70 minutes at 25 amps would discharge the battery to roughly 50 percent?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
