Ivylog
Apr 24, 2015Explorer III
The easiest way to ruin a AGM is to try and equalize it. You need a charger that you can turn the equalization OFF or has a setting for AGM. Same with your solar controller when hooked to AGMs.
CA Traveler, I'm going to add a 100 amp charger and a 1000W PSW inverter. If I could get my 2000W inverter/charger to put out it's rated 100 amps I might parallel them but on the generator I can only get 50 amps max and on shore power 75 amps. We boondock often so having more charging amps is important.
