John_Joey
Oct 13, 2015Explorer
I love to know how people can equate a lawn sprinkler system with a water supply system. A sprinkler system has black pipe and sprinkler heads, that's pretty much it. Doesn't have toilets, shut off valves, hot water heater, faucets, shower heads, pumps, strainers, ice makers, dish washers, black tank sprayers, outside showers, etc...
All RV's are different both from the standpoint of the manufacturer and what some prior owner did to them. Using pink stuff you're pretty much guaranteed not to have a problem.
Blowing out the lines you'll more then likely be just fine. If not, you'll know what to do the next year when you fix the busted part in the spring. Then next winter you can write on the forum how blowing out the lines down in Tennessee, won't work up in Manitoba and you need to do more.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
