JaxDad
Oct 13, 2015Explorer III
dougrainer wrote:dclark1946 wrote:dougrainer wrote:
Been blowing out lines for 36 years. Thousands of RV's motorhomes and Towables. We Warranty our work. NEVER had a customer come back with freeze damage. IF DONE CORRECTLY, Blowing out is the best way to go. That said, MOST Rv'ers will have NO clue how to do it correctly and MOST will not have a large capacity Air tank to keep up the required volume of air to do the job correctly. There are multiple items that MOST forget
1. Toilet valve
2. Black Flush Valve
3. Dishwasher valves and pump if equipped
4. Clothes washer solenoids AND drain pump if equipped
5. Icemaker and water thru the door if equipped
6. Following the Correct procedure for a Hydronic heating system, which cannot just be blown out. It must have antifreeze run thru it once blown out.
7 ALL P traps, even the one behind the Clothes washer if Antifreeze not pumped into and out of the washer.
8. The fresh water pump in line filter and running antifreeze thru it(water pump)1 cup is all it takes. Doug
What pressure do you use?
I have been blowing out our lines for 15 years with no freeze damage. Only use the pink stuff for the traps.
Dick
I have a special Air Hose pigtail with an adjustable regulator connected to a modified blow out plug. I set the air at 90 to 110. REMEMBER, as another posted, I ALWAYS have a faucet OPEN so the full pressure never is in the system. MOST RV Water systems will withstand up to 125 psi. I also have modified 120 volt pigtails to open various solenoids that require 120 to open(like icemaker water solenoids). I also forgot to mention----WATER FILTERS must be removed. Doug
Just to add to Dougs excellent advice, the pressure of the air is only part of the equation, the VOLUME of air is even more important in ensuring the water is driven out by the air.
I've spoken with several folks who were absolutely dead-set against using air to winterize because of damage resulting from doing it themselves. In every case there was 2 common problems, 1) they were using a VERY small compressor, and, 2) they didn't leave the air running long enough through each tap.
A little 2 or 3 gallon compressor does NOT have enough compressing capacity nor enough reservoir capacity to clear lines safely. If that's the size compressor you have you need to T in a big (12+ gallon) second air reservoir.
A friend didn't believe me about this so I had him run his 'winterized' m/h over to my place, I hooked it up to my shop air supply and he was amazed at how much more water came out of his lines.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
