NC_Roamer
Oct 17, 2015Explorer
RCMAN46 wrote:
Simple:
I do both.
First blow the lines with air then use the pink stuff. Much less dilution of the pink stuff from any water in the lines.
If you have a black tank flush do not forget to blow that line.
Ditto. After using the low point drains, running the water pump a moment, and then blowing out all the lines, I use the Country Fill setting on the water system to pull some pink stuff into the pump and it's connected piping. I also pour pink stuff into all the traps.
Had no issues last winter and we had temps in the low teens for several nights and one night is dropped to 9 degrees F. Around these parts, that's about as cold as it gets.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
