Garyl53
Oct 17, 2015Explorer
What is a recommended compressor tank size to be able to do a reasonable job of bowing out the lines at home? If not 3 gal. or 6 gal. then what? Is there a way to use the FW tank as an expanded pressure tank and then run pump and open valves one at a time? Assume you would need to seal off the FW fill vent tube but are there any other vents to a FW tank?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
