CincyGus
May 19, 2013Explorer II
I would load test the 12v gel battery to see if it is worth even keeping at this point. May be it will give you an extra day or so of power if brought along and swapped into the system once the 6v's gave up the ghost, might not be worth it's weight to even bring it.
You don't say how much solar you have but if you can make it for the 5 day trip without much issue and the 10 day trip is the only real concern, maybe renting/borrowing a Honda 2000 for that trip to help your recharging efforts might be the ticket this year.
I'm in agreement that not buying additional until you can replace buy all four together is the right answer for the benefit of your system over the long haul.
One other option is if you have a camping friend that wants to upgrade to a bit more battery capacity, give them a deal on your used 6v batteries and then go out and buy your 4 new ones together.
Enjoy your trips, sound like great times.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
