Fire_Instructor
May 19, 2013Explorer
CincyGus wrote:
I would load test the 12v gel battery to see if it is worth even keeping at this point. May be it will give you an extra day or so of power if brought along and swapped into the system once the 6v's gave up the ghost, might not be worth it's weight to even bring it.
You don't say how much solar you have but if you can make it for the 5 day trip without much issue and the 10 day trip is the only real concern, maybe renting/borrowing a Honda 2000 for that trip to help your recharging efforts might be the ticket this year.
I'm in agreement that not buying additional until you can replace buy all four together is the right answer for the benefit of your system over the long haul.
One other option is if you have a camping friend that wants to upgrade to a bit more battery capacity, give them a deal on your used 6v batteries and then go out and buy your 4 new ones together.
Enjoy your trips, sound like great times.
Think that I'm gonna get the gel-cell load tested... it may be junk, it's so old...
As for how much solar, it's in my signature block - 300W. I own a Yamaha 2400, just don't like to start it unless I absolutely have to....
I HAVE a friend who wants the two 6v, but on his new TT, the battery (single) is "sunk" between a-frame at the hitch, and if he raises it to the top of the a-frame for a double battery box, it blocks his ability to get the propane cylinders in and out of their molded nose compartment. Still working on a solution for that, as he really needs twin 6v for nighttime use of a CPAP!
As for buying in DE, what a GREAT idea! Not only will we be in DE for the race, but we travel through DE to get to Assateague, plus wife also usually wants to go to the factory outlets in Rehoboth Beach while we are in Assateague. Now I will have something to shop for!
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
