Boatycall's avatar
Boatycall
Question for those who have added electric water rod
Hey all,
I have gas-only for water heat. I've had sitting on the shelf for a while one of those 110v water heater rod kits.
For those that have done this--
Has there been any long-term adverse affects from removing the anode? And I know there'll probably be a lot of speculative comments and guesses, but I'd really like to hear from just the people who have actually done it.
  • I appreciate you doing that. I just love being woken up at 3am by someone's gas-fired WH going off.
  • Depending on the regions water you may never have a problem. ..around here the rods disolve like sugarcubes. .I'm thinking about using impressed current as a secondary protection method.
  • All I could afford wrote:
    I added hot rod 400 watt kit 2 years ago and love it. My water heater is located right underneath the dinette bench, and I always hated hearing the sound of the gas burner coming on and off throughout the day. With the separate thermostat on the electric element I keep it set about 20 degrees higher then the gas thermostat. Therefore in moderate use the gas never fires unless someone goes in the shower.
    No negative things to report
    This is how I set mine up also. I keep the gas on though for faster recovery when 4 people are showering in a row. My Atwood didn't have an anode, just a plastic drain plug.
  • Gjac's avatar
    Gjac
    Explorer III
    The only negative thing to report is be careful not to turn it on after you winterize it will burn out the element.
  • I added hot rod 400 watt kit 2 years ago and love it. My water heater is located right underneath the dinette bench, and I always hated hearing the sound of the gas burner coming on and off throughout the day. With the separate thermostat on the electric element I keep it set about 20 degrees higher then the gas thermostat. Therefore in moderate use the gas never fires unless someone goes in the shower.
  • Worth noting, since posting this earlier, I've already installed it. Only took about an hour. Anode looked virtually new when I took it out.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
