phemens
Oct 19, 2021Explorer
SDcampowneroperator wrote:
Both on one axle. You will need to lower and raise it to change out the spring, then align it to the centering bolt.
While you are at it its a good time to replace shackles, bolts amd bushings.
Shackles were all done 2 seasons ago (changed to the lubed kind)
I was under the impression I could lower 1 side of the axle at a time instead of both sides?
