Dirtdaddy's avatar
Dirtdaddy
Question on Coleman 100W Solar Panel "open circuit" voltage
I have what looks to be a Coleman 100W Solar Panel with a 30 amp Coleman controller in the trailer. It doesn't really charge my batteries, so I checked the open circuit voltage coming off the panel and it's under 13 Volts DC (This is when I remove the leads from the panel to the controller). I can not find a spec for the solar panel open voltage, but most other panels say it should be greater than 20 volts open circuit. Is it a fair guess the panel is shot? The controller rarely shows the indicator light it's charging, but does show the voltage of the battery.
Having RV issues? Connect with others who have been in your shoes.24,309 PostsLatest Activity: Sep 05, 2025
