mrad's avatar
mrad
Explorer II
Dec 01, 2018
Question on new inverter reading
My new 1200 watt pure sine wave inverter arrived yesterday. I just hooked it up to a new group 27 deep cycle. the LED read 12.9 volts. I then plugged a fan into it and turned it on. Voltage immediately dropped to 12.6. I then plugged in a 60 watt light bulb and it dropped to 12.4. Five minutes later, it was 12.3.
My understanding is that at 11.9 volts I am 60% discharged and should disconnect the draw and recharge battery.
Do my volt readings seem low or is the LED reading on my converter most likely inaccurate.
In a previous thread, I was told to get a volt meter. Would a dedicated volt meter be more accurate?
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
