mr_andyj
Jun 04, 2021Explorer
Always leave the generator door closed. As said, it is designed to pull air through a certain pathway. The RV outer access door is not related and can be closed or open. I suppose open it will let more hot air escape from under the coach.
The Onan moves a LOT of air over its cooling fins when running, you do not need to help it. RV outer door open or closed wont matter, there is a LOT of air being pushed across the Onan motor.
Driving or parked has no effect, doesnt matter.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
