rjsurfer's avatar
rjsurfer
Question on solar controller hook up?
I finished up most of my solar install today and I noticed an issue when hooking up the solar controller to the batteries.
I'm using an A/B Both switch to control what bank or banks I want to run.
Prior to the solar controller I had only two things tied to the output of the battery switch, my inverter and the connection to the converter in the distribution panel. Which worked fine.
When I went to connect the output or battery connection of the solar controller to the A/B switches output terminal, out of habit I just lightly touched the wire to the terminal and noticed a spark nothing big but as spark none the less. At the time I was running on the generator so I'm assuming the voltage was from the converters output. Sure enough when I measured the voltage it was 14.7 volts DC which is the output voltage of the converter/charger. I'm guessing I shouldn't have made the connection with the converter being powered up.
So as a sanity check before I make the connection permanent I want to make sure I'm not doing something wrong. I'm assuming that the solar controller is made to accept the converters output when running shore power. And the small spark was just normal :-)
Ron W.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
