Hi Almot,
Careful. My Blue Sky 3024di will not handle 400 watts of panels unless I use nominal 12 volt panels, which kinda sorta defeats the purpose of going MPPT. I can do 300 watts @ 33 volts input to the controller, allowing 125% for cloud effect. I'd hate to let out the magic blue smoke.
I think the next generation of Blue Sky can do more wattage, but they want a bunch of money for an upgraded chip. There is also zero warranty on the chip unless they do the installation (for a service fee, of course). So the answer is "it depends on the MPPT controller".
The rule of thumb for MPPT is the greater the input voltage the lower the efficiency of the controller. Magnum, with their new PT-100 claims 99%. I think my blue sky is only 96% when I do 33 volts input.
While voltage drop doesn't matter much for PWM installations, it does matter for MPPT because MPPT takes volts and processes them into amps. I would aim at 1% or less voltage drop from panels to the controller. So yes, wire size really does matter. I managed to squeak to about a 1% loss by using 33 volts of input, but my real reason for going MPPT was that panel cost per watt was $5.50 at that time, so I purchased MPPT to extract every watt I could. Today with panel prices as low as $0.28 cents per watt, I'd most likely use a fully featured PWM controller.
Hear Hear on "doing it right the first time".
Almot wrote:
Wrong again.
It's about wattage, not number of panels. 30A MPPT is enough for 450-480W array. Jack is correct, +400W is easier to do with 24V panels. Makes sense installing 2*230 or 2*240. High-volt panels need to be of close voltage, installing 195W now and adding 250W later would be a bad idea. One thing that Jack doesn't mention is that solar should better be done right the first time - cheaper and simpler.
There is nothing to "size" from roof to controller with few high-volt panels in series. Wire is the same MC4 #10, for a single 195W or 2*240W or even 3*240W. this is the beauty of high-volt panels - low amps, thin wire. The only thing that is changing is the wire gauge from controller to battery - beefier wire for bigger total wattage.
I have a feeling this is going to be a very long thread.
