Old-Biscuit
Mar 26, 2014Explorer III
wa8yxm wrote:
One thing you might find.... As I recall "Soft" water is de-mineralized.. The Anode rod.. Well that is a mineral (Zinc most likely) and thus soft water will eat it fairly fast. So if you go soft, check the anode often.
'Soft water removes calcium & magnesium.
RV Anode rods are either Aluminum (MFG) or Magnesium (aftermarket--option)
Magnesium dissolves at a faster rate than Aluminum regardless of water source.
If WH (Suburban) has an anode rod it should be checked routinely whether Aluminum or Magnesium.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
