phemens's avatar
phemens
Questions about wiring for Samlex inverter/charger/converter
Hi,
In the process of installing a Samlex 3012 inverter charger. This will replace existing stand-along 2000W inverter, along with my Boondocker converter/charger.
Couple of questions, sorry if these seem basic, but want to make sure I do it right (not an electrician, but can get it done properly with right guidance!)
I will wire directly from the shore power receptacle (the marine style twist) to the Samlex Grid input using 8 AWG. Right now it goes to the distribution panel.
Samlex wired to bank of batteries (4x100AH LIFePO4) with 4/0 (fused)
Samlex grounded to chassis.
Samlex AC output (8AWG) back to Main breaker in distribution box (?) - this is the part I'm unclear on. Part of the confusion is that the way the rig is wired now, if I cut the main breaker on the distribution panel, all goes dead on AC - fine. However, if I leave breakers on, but turn off power to the Boondocker converter/charger, I lose power to the refrigerator (maybe other things, haven't checked) - does the fridge require 12V to run on 120V?
Thanks in advance
