coolmom42
Oct 25, 2020Explorer II
Vw triker wrote:
Do you have a gravity fill port?
That is the correct one, I have a plastic one.
The port that goes to the fresh water tank is not set up for gravity fill. The male hose end has to be screwed into it. It looks just like the city water inlet. This is the port I want to switch out.
I'm assuming for winterizing with air, I use the city water inlet. Is this correct?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
