valhalla360
Oct 26, 2020Navigator
BurbMan wrote:
I have yet to see a gravity fill where you don't need a funnel to fill from a jug. So I wind up balancing a flexible funnel while trying to pour a 5 gal jug into it. Seems much easier to have a spare 12v pump as was mentioned...build a little rig so you can screw the output to the fill valve and stick the suction end in the water jug.
Get ahold of a short piece of PVC pipe and a 90 degree bend. A 6-8inch piece that sticks into the inlet hole connected to the 90 degree bend and a 2 inch piece sticking up from the 90 degree (we just dry fit and it's worked without leaking or falling apart). Now a funnel sits upright and the water is directed into the inlet with ease.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
