DrewE
Oct 28, 2020Explorer III
coolmom42 wrote:
Campgrounds without water at the site (common around here) often have unthreaded faucets scattered around. Will one of those water thief adapter things hold on well enough to get a pressurized fill? Or do they pop off pretty easily? I've only ever used one for a gravity fill tank.
In my experience, if the campground has a dump station, there's nearly always a (pressure) potable water fill there or nearby, as well, which you can hook a hose up to--even if there are no hose connections elsewhere.
At least in my experience with my RV, I need to refill the fresh water tank at about the time the gray water tank is getting full-ish. Thus, I've yet to require a water thief. That said, I most certainly haven't been camping at the exact same parks you have been.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
