C-Leigh_Racing
May 14, 2014Explorer
Thank you Mexicowanderer.
Looking at this Micro, its like it dont have an outside cover like most microwaves & has like a metal slide rack built in that it fits into, with two long bolts at the top to hold it in place.
A regular cheap micro would be a good idea, but then I got to build something in the area where the old one was at for the new one to sit or fit into.
The #1 fuse, small round one like a car fuse, it checked out ok.
Now to find that #2 fuse location your referring to.
I probably will pick need to your brain on that push button breaker deal, sounds a lot better idea than replacing a fuse every time I turn around.
Thanks again, Neil
Thanks again, Neil
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
