MEXICOWANDERER's avatar
Apr 26, 2014
QUESTIONS re: MEGA-WATT 33-AMP POWER SUPPLY
This critter can be found on eBay. It is a switching type power supply.
Supposed to have an ultimate amperage potential of 33, voltage adjustment of 10, to 15, and work fine as a long term battery CHARGER as well as a power supply. The unit has good reviews.
I read all the time on this forum about folks PARALLELING their switch type "converters" to increase total charging ampacity.
But the -supplier- of this switched unit says to not connect more than one to a battery or they will "burn out".
I simply do not have the experience with PWM switch controlled power supplies to appreciate -why- car battery chargers yawn at being connected in parallel to a battery or bank and yet this one would "burn out".
Would not an appropriate electrolytic capacitor serve to suppress the amplitude of whatever ripple the PWM frequency operates at?
Only experience can yield an answer to this. I sure would like to travel with a 66-ampere charge rate in a small toad.
  • Mexi knows more about batteries, than I will ever learn
    His question really is what he is asking
    About the reliability of two PWM chargers together
    I know I have used various combinations power supplies and converted or chargers together and have never encountered a problem
    Mexi do you have a link to the ebay sale
    I wonder if they meant to say two would burn up a battery
    Which of course would depend on the battery`s involved
  • From Mean Well's website for one of their supplies:
    B3. If we need a 600W output, can we use two units of S-320 connected in parallel?
    Ans:
    No, you can not do this connection because S-320 is not equipped with the parallel function. When two power supplies are connected in parallel, the one with higher output voltage will share more loading and deliver more (even "all") power to the load and cause these two power supplies to be unbalanced. We suggest using PSP-300 or PSP-500 because it is equipped with the current sharing function.
    I guess it depends on how they handle overcurrent conditions.
    You'll have to give it a try to see if the current limit works by rolling back the voltage, or latching off until the load is disconnected or the power supply power cycled.
    I don't see how it would burn out unless the power supply was a '4 quadrant supply' (doesn't just source but can also sink power) which they usually are not.
  • Matt, you should know Mex by now. He's MORE than familiar with charging batteries with a manual charger which is what this is. You regulate the voltage by changing it by hand.
  • Small Problem.
    That is exactly the kind of thing that is a bad battery charger.
    It is a constant and regulated voltage. You want something that can time or sense the battery situation. Trust me please, I did boat work before the depression and I have seen and repaired a lot of this.
    Another problem is that even if you parallel two and they survive (a good chance actually), you will only get your 66amps for a short time. Even to get that, you will have to set a charge voltage that is dangerously high. As soon as the bank terminal voltage comes up, you will loose charge rate. If bump the supply voltage up, you just over heat and boil the batteries to death.
    In times of old, a regular converter was just this sort of thing (but the stone age version) and they destroyed more battery banks than I could count.
    Matt
  • Small Problem.
    Matt
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
