Learjet's avatar
Learjet
Quick...and almost easy Progressive Industries EMS-HW50C
just installed the Progressive Industries EMS-HW50C behind my 50 amp panel...here is the "quick" and almost easy way to install one ;)
I know the display is side ways...but it is right above my stairs in my 5th wheel...I can also see it from outside with the door open.
I had enough slack to cut the shore wire and insert the EMS.
I did say quick and easy...;)
and because it didn't really happen with out pictures...
  • Nice,
    Here's my installation of the 30A EMS.
    Since it is like Grand Central Station inside of the cabinet with wires & plumbing running every which way I made a mounting sled for my unit.
    The opening with the sled installed.
    The final install.
    Sorry, the links to my pictures won't load. Not sure if I screwed up or if the moderator needs to intervene.
  • sdetweil wrote:
    Nice work! Does yours hum/buzz?
    I added one and an ATS in a kitchen cabinet with the distro panel and converter.
    Yes, that is normal for a large contactor like the one they use.
  • Nice work! Does yours hum/buzz?
