Scott_MalkinsonExplorerOct 28, 2016quick and easy inverter questionDoes the size of the power inverter make a difference in the draw from the battery? Meaning, if I am pulling 300 watts through the inverter, will it be the same draw from the battery regardless if its...Show More
agesilausExplorer IIIOct 28, 2016No inverter is 100 percent efficient. Meaning you lose power when you invert it. That's why inverters run hot. Here's a page of info:Link
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
Related ContentInverter Bad?Quick connect exterior shower hose doesn't connect.Inverter installQuick inverter questionA Quick Question
