SoundGuy
Oct 29, 2016Explorer
Scott Malkinson wrote:
Ok, didn't think it would matter much. Thanks
The best answer so far is that from road-runner ... any wasted energy is just that - wasted ... and larger inverters will inherently chew up more power just idling than will a much smaller inverter. Ideally you want to match the size of the inverter to the intended load but that can be hard to do if one load is 30 watts while another may be 800 watts. Practically speaking, whether you choose to use one larger inverter for everything or several different sized inverters depends on how you intend to use them ... doesn't make much sense to power your trailer "whole house" with a small 200 watt inverter but it's entirely practical with say 1000 watt or greater. Individual inverters powering individual devices however raises the question as to where you intend to physically locate them in the trailer and how you're then going to get power to them. For many of us this is no solution at all and we'd much rather take any additional loss created by one single larger inverter and keep the wiring simple. In my case, I originally used my 1000 watt PSW inverter "whole house" but have since installed dedicated receptacles inside the camper where I want them, powered directly from the inverter which is only turned on when it's actually in use. Otherwise it's off and drawing no power at all.
As you can see, not such a simple answer as you had suggested in your thread title.;)
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
