Chum_lee
May 23, 2016Explorer
If you want to know the correct OEM part numbers (for comparison to Dayco, Goodyear, etc., or any other after market vendor) before you buy, go here:
www.fordparts.com/Default.aspx
Go through the part identifier queue just like the guy behind the counter at the Ford dealer does. Ford usually has drawings of the original part and the assembly it fits into for your comparison.
99% of the time, if available, OEM Ford parts will be more expensive than after market parts, but, if you order the correct part number based on date of manufacture, VIN, year, model, engine, transmission, they WILL fit perfectly and WILL last as long as the original hoses. That said, many after market parts are better and cheaper, BUT, often they require some "field adjustment" to fit correctly. The choice is yours.
Chum lee
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
