pianotuna
Jun 11, 2013Nomad III
Hi BFL13,
If the bank is 740 amp-hours the minimum wattage needs to be about 450 watts. That's *plenty* to run loads during the day and replace the amp-hours used when the sun is down.
If the bank is 232 amp-hours for equalization the size only needs to be about 140 watts. BUT 140 watts on five perfect solar hours is only about 50 amp-hours returned to the battery bank. That is far less than what may be being used unless the owner is a total power miser. It would be a great system for storage.
Given how "power hungry" RV's are the battery bank would not be fully recharged. So for the smaller 232 amp-hour bank probably 350 watts would be better.
With your own bank you now have enough to replace the amp-hours used in a day.
BFL13 wrote:
PT--
"With a bank such as mena's at 740 amp-hours that would leave him with lots of power. If the bank is just a pair of golf cart batteries, more watts are needed to get back the amps used in a day."
Lost me there. A smaller bank would get lower in SOC but accept more of a charging rate (amps /bank size in AH) for faster charging--but need more solar for those higher amps. Big bank at higher SOC range = lower charging rate--but is that at lower amps? Might be more amps (bigger solar needed)--depends on the bank size and actual SOC and voltage. Also if lower amps more likely to run out of time to replace the AH.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
