pianotuna
Jun 11, 2013Nomad III
HiTech wrote:
First guess:
1-5 watts/100 ah - below self discharge
yes, but 5 is enough
HiTech wrote:
5-20 watts/100ah - battery maintainer
yes
HiTech wrote:
15-70 watts - small
yes with a cheap controller
HiTech wrote:
50-200 watts - medium small
200 watts into 100 amp-hours is overkill, unless the bank is really that small. I'd go 60 to 150. It would be nuts to boondock with just 100 amp-hours.
HiTech wrote:
75-300 watts - medium
Overkill on the 300, again assuming bank is only 100 amp-hours. The range between 75 and 300 is too wide.
HiTech wrote:
230-400 watts - medium large
Overkill on both ends for 100 amp-hours, a good size for 350 amp-hours
HiTech wrote:
350-800 watts - large
Just right for 232 amp-hours, but overkill on the 800 watts. 800 could service over 1300 amp-hours. Too much range between the two numbers. A much larger controller would be required for 800.
HiTech wrote:
Jim
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
