Almot
Jun 12, 2013Explorer III
Old & Slow wrote:
A question came to mind. Wonder how much free energy can be harvested FREE under the right conditions in twenty five years, with this little setup? Maybe I'm richer than I think.
You will return the cost of 120W panel and controller after 10 years approximately. Input your data HERE. Choose the state, the city, then dial 0 in the "Array Tilt - Degrees", and dial 1.2 in "DC Rating - KW". The calculator doesn't accept value below 1 KW, so you have to put 1.2 KW. Then divide the annual $ cost by 10, because your panel is 120W, not 1.2 KW.
More if you tilt the panel.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
