lc0338 wrote:
The radio is very near an under cabinet light and where the radio appears to be getting it's power source. I can turn that under counter light on and it does not impact the radio volume. But, if I turn on the main light switch on the other side of the trailer the volume becomes reduced. I have noticed that if I just turn on the 1 under counter light the converter does not turn on. When I turn on the main light switch the converter comes on... so I'm thinking the converter may be playing a role in the interference. The trailer is a 2007 year model. The light bulbs are have 921 printed on them. If the under counter light does not affect radio volume don't know other light bulbs would.
More info is needed ... are you the original owner of this 2007 trailer, if not perhaps some of the bulbs have been changed to LEDs. If they're all 921 incandescent bulbs then perhaps the converter is the cause, in which case turning it off and running on battery power might solve the issue. If that works then it's possible the converter is failing or there's a loose ground ... but that could be just about anywhere and very difficult to locate, though checking the connections at the converter would be the obvious place to start.
