Brodie3Az
Sep 21, 2014Explorer
A question would be whether the warranty is still valid.
It sounds like the nut or nut and plate have come loose from the top of the tube.
support the trailer tongue and remove the complete jack assembly from the hitch. Try to extend the tube with the motor to gain access to the nut/plate. May need to disassemble the power head so that the threaded shaft can drop down and out.
The nut/plate probably needs to be welded back to the tube.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
