naturist
Oct 29, 2017Nomad II
Depending on outside temperature and size of tanks, you could easily run out two tanks in only 2 or 3 days. RVs are typically poorly insulated and furnaces are thirsty.
How big is your RV, how cold did it get, how warm did you keep the inside, and how big are the tanks? And is your RV a 4 season model or a “standard” one?
I know of no RVs that have 100 lb propane tanks, but I often see such tanks hooked to RVs being used by full timers in cold areas. If you are trying to keep a 30 foot standard RV at 75 or 80 degrees on 2-20 lb tanks in freezing weather, both tanks will indeed run dry in just a couple days.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
