CrankyLass
Oct 29, 2017Explorer
time2roll wrote:
So fill them up and carry on. If running the furnace at night always check in the morning to see if the regulator indicates one tank is empty. No furnace and you can check once a week.
You may have had a short fill. See how it goes with the new fill. You should have 2x 30 pound cylinders. If frequent filling continues you may need to have someone do a leak check but is rare on a new RV.
In time you may consider getting a couple more cylinders or if in one place rent a 100 pounder from the local supplier.
BTW it is time for a heavier blanket and comforter. Heated mattress pad is excellent suggestion.
welcome to the forum ;)
Thanks for the welcome :) I will tell my hubby about the 100lb cylinders :)
