Old-Biscuit
Oct 29, 2017Explorer III
According to your profile:
2018 Outback 330RL
Specs show TWO 30# propane cylinders
Furnace is a 30,000btu
Temp set to 72*F......yep suck up that propane
Especially when maintain heat in a 38' trailer
Space heaters to 'supplement' furnace (not in place of....need that RV furnace to keep underbelly warm)
Electric blanket....so you can lower night time furnace set point down to 62*F (or lower)
Also check around for air leaks...trailers are NOT air tight and all that heat can get out. Slideout seals (3 slideouts), windows, entry door, vents, around fridge enclosure etc.
2018 Outback 330RL
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
