AllegroD
Oct 31, 2017Nomad
Do you have a sealed underbelly? Do not know if someone said this but check out your wet bay, water tanks and water lines. They need heat so they do not freeze. Electric heaters and cat heaters may not be a good answer. Most wet bays, if they are heated, are heated by the gas furnace. If configured well, you may be able to bypass this with a 200 Watt Heater and a Thermo Cube. Do not let your water lines freeze or you will have bigger problems.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
