MEXICOWANDERER
Nov 01, 2017Explorer
THE TERM "IS FULL"
IT DEPENDS ON THE MEANING OF THE WORD, "IS" ANY WORD AFTER "IS" IS IRRELEVANT. (William Jefferson Clinton)
Argument reminds me of FULL QUARTER POUND HAMBURGER!
(Before cooking. Meat is 50% fat)
FULL 3/16 pound beefgristle hamburger?
*Note: The term "full" describes the level of fill according to our terms. Due to manufacturing, temperature and processing variances, it is not possible to accurately describe amount of contents.
HUMONGO CEREAL 18" tall box. Open and find inside contents half full. Disclaimer: Due to package settling you may find contents less than full (What's that you say? 2-step process? Fill then vibrate contents then refill the box? We've been doing it this way for decades. Isn't a new appearance of our package good enough for you?)
When gasoline is delivered at a gas station, tanks are stabbed with a 12 foot long measurement pole. With yellow water tattletale paste on the end. Fuel is SOLD ACCORDING TO TEMPERATURE AT DELIVERY by volume.
The CORRECT way to dispense LPG is by weight but the process is too cumbersome to make dispensing by weight practical. I have filled everything from one pound disposables to 500 gallon set tanks. At 90% fill at ZERO FAHRENHEIT in Bishop California (pure propane) cylinders were taken to Mexico and sat in the sun at 90F ambient temperature. Not one EVER relieved due to overpressure. This was in the days of the ten percent valve fill level. Rock the tank and get liquid.
Houdini grade 3 walnut shells and a pea sales, impress me not. There is a 100 lb cylinder that is loaned to me. It's empty of pressure. But there is at least two gallons of process oil sloshing in the bottom. Tomorrow the tank gets taken to the salt flat and emptied into a deep hole which is then lit and burned off (ashes to ashes). The cylinder then goes to an LPG (butane) fill station where tare is taken before my eyes, the cylinder is filled by weight to the 10% bleed off. Butane has less than half the head pressure of propane. When I pay for full i expect full
I do not own one of these tee shirts. Nor do I wear a NO BAD DAYS tee shirt during a hurricane...
