hmknightnc
Feb 14, 2013Explorer
Jawsinparadise wrote:
Extremely strange to read all the opinions re this subject. Most written by author "OLDMAN"
I purchased my new Wildwood last month. The contact person that did the paperwork was a "OLDMAN".
In my contract I was to have 2 batteries. What was installed were 2 6v in series. I wanted 2 12v in parallel. Twice the ccp as 2 6v. If one 12v fails you have another. If one six fails you have nothing.
How one assumes 2 6v are equal or better than 2 12v has little knowledge how batteries are rated in series or parallel.
Welcome to the Forum. I am sorry to tell you but what you just stated is generically just flat out wrong, factually incorrect.
- Unless you are in the habit of checking your batteries several times a day a failed 12v in parrell with another 12v will bring the good battery down as well resulting in loss of battery power. So in a practical sense a failed battery in a 2 battery bank results in a dead battery bank regardless if they are 2 6vs in series or 2 12v in parellel
- A typical 12v battery install by the manufacturer is an 80AH battery and putting 2 of these in parellel results in 160AH battery bank at 12v. A typical 6v golf cart battery is 225AH at 6v, wiring 2 in series gives you 225AH battery bank at 12volts. This is approximately 50% more power available at about the same price as 2 12volts
- A 6v golf cart battery is a true deep cycle and withstand the rigors of RV use much better than the typical 12v marine batteries unless you are talking about a very expensive (>$200 each) 12v deep cycle battery
- Battery failures are actually very rare with just barely reasonable battery care. Over 20 years experience with trailers and I haven't had a castophric battery failure yet. Worrying about battery failures with reasonable care is a waste of time
BTW, I'm an engineer in the power industry with over 27 years experience in power systems including battery banks and power backups.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
