HiTech
Feb 20, 2013Explorer
wa8yxm wrote:
Actually the Six volt deep cycle do not so bad as starting batteryes, The starting battery in my RV is around 80 amp hour. The six volt pair 220 (older) so a 160 amp load is 2x the amp hour capacity for the cranking battrey but only about 3/4 of the capacity on the deep cycles, NOT a heavy load at all.
And that's the crankey battery for an 8.1L Vortec V-8,, As for the Onan, I've crenked it with a 27 amp hour AGM
Ah across different battery types does not have much to do with cranking capacity though, and AGMs tend to crank really well, even the small ones. I crank a high compression race car with a 32 Ah AGM.
Jim
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
