ktmrfs
Feb 21, 2013Explorer III
wa8yxm wrote:ktmrfs wrote:renoman69 wrote:
You are WAY better off with 2 6 volts batts and no I won't explain why. Just trust me.
for many applications I agree. There is one that I believe 12V will be better. That application is when the dominant use is with a high power inverter (1KW and up) or other constant high current draw (>50-75A). Then 12V banks are IMHO a better choice. They offer low voltage drop with high current, and with more banks for the AH needed, each bank is also supplying lower current.
But if your draw is more like most 12V appliance draws then yes 6V is the way to go, even if you occasional have a high current draw.
I disagree.. You take a pair of six volt 225 amp hour batteries and draw say 100 amps off them, that is 2/5ths (40%) of their 20 hour rating, (Of course modern six volt are 230 but I'll stick with 225 for now cause that's what mine are. (older)
You get say two Group 29's, roughly 100 amp hours each and while it is true that each battery is only providing 50 amps that is a full FIFTY PERCENT (1/2) of their 20 hour rating. So again the six volt win
Group 31's. you have a total of about 260 Amp hours. But only just a bit better.. 5/13ths of the total capacity..
But Group 31's won't fit in the same tray.
Though that said: Starting batteries are designed to deliver amprage that EXCEEDS their 20 hour rate, That is a single Group 24 can easily deliver more than 150 amps (2x it's 20 hour rating) for a short period of time.
But it can also only deliver about 20-25 percent of that power before it begain to suffer big time, where as the six volt pair can deliver half their power before they really need a recharge.
It isn't the AH that is the issue with high current draw, it is the internal voltage drop on the cells that poses a problem. 6V have noticeably higher internal resistance, and for the same AH capacity double or more the current/cell that a 12V bank will have. Based on personal experience, trying to power a 1000W load (80-100A) from a pair of Golf carts for an inverter works if the 6V bank is charged to 75-80% or more. much below that and the internal voltage drop hits the cuttoff. Not necessarily so with "equavalent" 12V bank. First 12V will have lower drop, second for a 200AH bank, you'll have at least two 12V so each one is only delivering 40A or so vs the 80A of a GC pair. Much less internal drop so you can run an inverter at a lower SOC.
And for things like a microwave, usually your looking for a few minutes of run time at most, so it isn't as much AH as amps that is the big need.
Others with GC and big inverter loads have had similar results.
And it only gets worse if you try to power say a 2000W inverter from a pair of GC vs. 12V. 200A REALLY sags a pair of GC.
Now, since we only occasionally use the microwave when on battey power the GC bank is still the best choice for overall battery life and battery run time. And that is probably the case for most of the folks on this board. But if your load is constantly high current then 12V deserves consideration.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
