wintersun
Feb 24, 2013Explorer II
The lower voltage batteries are used to minimize battery weight. When you get to the large industrial batteries they are 2 volt. Look at the weights and you can easily understand why two 6-volt batteries are preferable to a huge 12-36 volt battery. RV's often use 6V batteries but they were not the intended market for them.
My truck has two 12V batteries and I am very glad that GM did not put in a special 24V battery as it would have a 150 lb. weight that would require a crane to install safely in the engine compartment.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
