Jawsinparadise's avatar
Feb 14, 2013
re 12v vs 6v Batteries
Extremely strange to read all the opinions re this subject. Most written by author "OLDMAN"
I purchased my new Wildwood last month. The contact person that did the paperwork was a "OLDMAN".
In my contract I was to have 2 batteries. What was installed were 2 6v in series. I wanted 2 12v in parallel. Twice the ccp as 2 6v. If one 12v fails you have another. If one six fails you have nothing.
How one assumes 2 6v are equal or better than 2 12v has little knowledge how batteries are rated in series or parallel.
  • Jawsinparadise wrote:
    ...I wanted 2 12v in parallel. Twice the ccp as 2 6v. If one 12v fails you have another. If one six fails you have nothing.
    What is ccp? I am unfamiliar with that rating. Your theory and your math is suspect, how about further explanation?
  • Batteries are like tires. You let them down, they'll let you down.
    -Tom
    Please explain the capacity difference.
  • Oldmen rule :B 2oldman just does the search for you. Draw your own conclusion.
    You had a vague contract and are unsatisfied.... what did the dealer say?
    BTW what size 12v? What size 6v?
  • I believe the correct spelling is 2oldman or somesuch. If you are going to slam someone at least spell their name right.
    In any case, you are wrong, I think you are a troll.
    Welcome to the Forum. I am sorry to tell you but what you just stated is generically just flat out wrong, factually incorrect.
    - Unless you are in the habit of checking your batteries several times a day a failed 12v in parrell with another 12v will bring the good battery down as well resulting in loss of battery power. So in a practical sense a failed battery in a 2 battery bank results in a dead battery bank regardless if they are 2 6vs in series or 2 12v in parellel
    - A typical 12v battery install by the manufacturer is an 80AH battery and putting 2 of these in parellel results in 160AH battery bank at 12v. A typical 6v golf cart battery is 225AH at 6v, wiring 2 in series gives you 225AH battery bank at 12volts. This is approximately 50% more power available at about the same price as 2 12volts
    - A 6v golf cart battery is a true deep cycle and withstand the rigors of RV use much better than the typical 12v marine batteries unless you are talking about a very expensive (>$200 each) 12v deep cycle battery
    - Battery failures are actually very rare with just barely reasonable battery care. Over 20 years experience with trailers and I haven't had a castophric battery failure yet. Worrying about battery failures with reasonable care is a waste of time
    BTW, I'm an engineer in the power industry with over 27 years experience in power systems including battery banks and power backups.
  • " I wanted 2 12v in parallel. Twice the ccp as 2 6v.......
    How one assumes 2 6v are equal or better than 2 12v has little knowledge how batteries are rated in series or parallel. "
  • Getcher Front Row Tickets Right Here!!!
    Religion! Politics! Drugs! 2 six's versus 2 12's!
    Guaranteed action, or yer money back!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
