Lakeplay
Jan 09, 2019Explorer
DSteiner51 wrote:
I had a Honda engine carberated that unless the gas was turned off the carb would allow gas to flow into the engine while going down bumpy roads. New engine with <10 hours, missed so bad it would hardly run while smoking horribly. I drained the crankcase and put new oil in, replaced the spark plug and the problem was solved.
Could this be a problem on an Onan too? Have you checked the oil level to see if it has risen?
Oil level hasn't changed. I have only owned it for 6 months. One thing I noticed right away was a lot of oil under the generator. Might be a crank case gasket leaking.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
