bartrak's avatar
bartrak
Generator replacement
I have a 1995 gulf stream conquest class c that I need to replace the generator.I would prefer a Onan but can't find one that will fit the opening. I removed a genrac, I have an opening of 30 1/2" wide by 16" high. Any thoughts or suggestions welcome.
  • Well sometime is pays to keep checking, turned out the avr was bad along with dirty rotor where brushes contact it, Gen is working as designed now, saved me a bundle.
  • My Generac is the NP 50g 4500 watt. I have been messing with it since I took it out and found the brushes were not producing, cleaned slip ring and now have a steady 8vdc. It will work momentarily then quit I think the avr is bad. May be worth investing a little and just keep what I have. The generator is is a 1995 model but has very few hours on it. The rv only has 7200 miles on it and i have put about a 1000 of them on it since I have had it. Rv belong to an older couple and he had cancer and passed away. Has been under cover since day one. So I may be having secon thoughts.
  • you don't mention what model generac you took out of your RV, but hopefully the Onan 4000 Microquiet will fit in the available space.
    The Onan has 1 30amp circuit breaker, so that is probably smaller than the Generac. It will easily run one ac unit plus charger/converter.
    If you run microwave or hair dryer, you may have to practice some energy management (turn off ac unit!) And you will probably have to extend battery cables, fuel line, a.c. wiring, as all Generac hookups are on right side as you are looking at generator, Onan hookups on left side.
    Onan has an optional hanger mount bracket that might help with the installation. Good luck with your project.
  • Article if the July MotorHome magazine about putting an Onan RV OG 4000 in a class C.
  • As installed in my Winnebago, the factory selected Onan 4000 Microlite also will not fit through the access door in the side of the RV. The generator is removed and replaced through the bottom (mounted on rails, the compartment has no floor).
    The only thing that has to regularly fit through the access opening is the removable part of the generator cover.
  • j-d's avatar
    j-d
    Explorer II
    I have the manuals for the ONAN 4KY series. The 4000 series mentioned above has the following minimum compartment size:
    Length (parallel to the side of the coach) - 30.5"
    Width (perpendicular to the side) - 20"
    Height - 14.4"
    So this very popular generator should mount in your compartment, with over an inch to spare at the top.
    Just be sure you provide the specified air flow.
    Nice thing about 4KY is the Muffler is inside its housing also. All you need clearance for under it, is the Exhaust Pipe.
  • An Onan Microlite series is about the smallest.
    I am guessing the dimensions you gave are for the compartment.
    RV QG 2500
    RV QG 3600 lp/4000
    Most Onans are installed using a pan installed from the bottom.
