wa8yxm
Nov 11, 2023Explorer III
dougrainer wrote:
That is an Atwood. The Tstat and electric element are behind that black plastic box. Odds are from how old the W/H is, the element has burned out. Doug
Atwood the T-Stat is outside comprtment and is the same T-Stat as the propane side.. Same for the ECO It's surburan that uses two pair of T_Stats.
The faint light when siwtched off indicates either a mis-wired switch or a bad control board (The black thing upper right outside) or other wiring issue I'd rank the suspects in that order.
On the switch there are 3 contacts. HOT-Switched-Ground
HOT will have 12 volts to any solid ground. Does even if disconnected
Ground will be the SAME COLOR as on the propane switch. Likely either black or white .... And switched. is the one remaining
Look at the propane switch connections.. Hot and ground are the same on both and should be the same color wire.. The "Switched" lead will be.. the remaining wire. and likely different color depending on Gas or Propane.
Might also be a bad switch.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
