darealmccoy
Aug 14, 2013Explorer
I had Bigfoot levelers added to my Concord in Lakeland, FL at a shop that does 5 or 6 sets weekly in June. Cost was $3800. I got the set with the remote. There is a cheaper set that has a hard wired actuator and a more expensive set that is fully automatic. Bigfoot makes them specifically for Class Cs. I used them on several occasions and they are fantastic.
I chose Bigfoot over the HWH because they do not use springs to retract and they do not take up a compartment for the pump, etc. They are retracted hydraulicly and the pump unit is located under the coach inside the frame.
Check the Bigfoot website and give them a call. I really like the remote as I can stand outside and make sure the jacks are properly extended and place wood pads if needed.
There is no way I would hane a MH without a leveling system.
Dave
Dave
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
