Re: Autoformer
Plug in the autoformer to boost the voltage. Then plug in the surge protector. It will shut off the RV at a low voltage, so if that was plugged into 105 volts, it would be cutting off the power when it really does not need to - because you have the autoformer.
Good luck!
Fred.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
