joe0508
May 26, 2018Explorer
batteries
I have something funny that happened to me the other day when i had a drained starting battery.After i jumped it off i ran it for a while and tryed to start the generator while the motor was running.A...
MrWizard wrote:Everything is working fine now.When the generator started the speed monitor went back down and the windshield wipers just barely moved.The only thing when i shut the motor off it was like the starting battery didnt recieve one bit of a charge.No juice so what ever.The headlights wont even come on but the generator started right up without the motor on without any problem.I guess its time to buy a new starting battery.The last time this happened was when i wired the house batteries the wrong way.I missed my step up because it came out so hard.Do you know if the onbourd generator will charge the starting battery?The starting battery is not hooked together with the house batteries.I have a 92 thor pinnacle.With a 4000 watt onan generator.
is everything working properly Now ?
starting battery was not charged 'enough' YET !
load spikes from the the generator 'starter' ? causing transients on the chassis electrical system
