Grit_dog
Feb 20, 2024Navigator
I believe you have very likely diagnosed it correctly.
To verify, I’d find your separator and re-create the old scenario and check power is or isn’t goin where it should.
But it sounds like you’re right.
if looking for a replacement, I have had a Blue Sea ACR in our boat since about 2010. It still works great.
RT170P
Feb 24, 2024Explorer III
Thanks Grit-dog. The person assisting me was an actual mechanic (my level of knowledge is looking for the giant "on/off" button 😁), and he tested everything, including every fuse in the near-by box... definitely the separator. And thanks for the replacement suggestions; I'll dig further to see what is recommended specifically for the Roadtrek, but what I've seen so far, a good, standard separator will work.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
