The answer is, anywhere you want it. Were is going to be convenient to have access to it? Close to the battery of course as you can.
Another option is to use a solenoid switch, the old mechanical kind, or a large relay to connect/disconnect. The only advantage of this method is you can put a small switch anywhere in the camper to operate the solenoid switch or relay. The switch will draw a small amount of power, so it will be a drain, but using a relay you can wire it that when you cut the battery OFF that the switch uses no power. This is called NO I think- Normally Open. The other setting on a relay is NC - Normally Closed. It would be the 87a terminal on a typical relay, where when no power goes to the relay the relay conducts the power, and when power is sent to the relay via the switch the relay cuts the battery power off. If you conect to the 87 terminal it is the opposite.
So, you can wire it that turning the switch off (using no power) also cuts the battery off. This means that when you have the battery power on the switch will use a tiny amount of power too.
You would have to wire the switch directly to the battery so that when the battery is cut off the switch is not dead also.
If interested we could walk you through this in more detail.
Also, a cheaper route is to use a circuit breaker instead of the big expensive on/off switch. Breakers for DC come in many amp ratings. I use a 100amp breaker for the battery cutoff.
