VaMark
Oct 08, 2014Explorer
Thanks for all the replies. The first thing I am going to try is to weld pieces of ABS material onto the fitting where the bolts go thru and tap threads in it and bolt it together that way. If that doesn't work I am going to try cutting and removing the old valve assy. from the pipe, by chisel or special tool, then glueing a new one on.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
